最强大的翅片换热器流路设计软件:Unilab EASY
Steven.liu 发表于 2020-10-5 19:57:40 | 显示全部楼层 |阅读模式 打印 上一主题 下一主题
  • 文件大小7MB
  • 上传时间2020-10-05
制冷系统十大仿真软:最强大的翅片换热器流路设计软件:Unilab EASY
UNILAB EASY is a specific independent application that collects all necessary
constructive information of an heat exchanger coil and lets the automatic creation
of circuits
This software allows to create all the necessary information for the constructive
design of the elements of a heat exchanger coil, such as the frame and manifolds
It can be made either importing data from a calculation of UNILAB COILS, either
independently. In addition, this software is enhanced by a procedure that allows
the creation of a fully automatic circuitry required, choosing between one or more
solutions. To complete the software, there is the 3D design, drafting and the ability
to export drawings in various formats recognized by the most common three dimensional
drawing programs
Automatic creation of the circuits: according to the number of the circuits the
software directly suggests you one or more layout solutions. It is able to
handle tubes skipped, bends and U-bolts.
Manua/ creation of circuits possibility to manually create, save or load
patterns.
Isefu/ warnings that suggest guide the end user in the creation of the
Collection exportation of detailed information, necessary to build the coi/
heat exchanger(ame &manifolds), he/pfu for the Production Dept(cost and
Vew of the coi/ in 2D and 3D, with the possibility to export drawings (2D in
DWG, D in ASCII STL, Binary STL, IGES, OB, STEP Bitmap, EMP)
Independent software, compatible with UNILAB COILS projects. Possibility to
open and load projects created by using UNILAB COILS. software
UNILAB EASY是一个特定的独立应用程序,它收集所有必需的信息
换热器盘管的构造信息及其自动生成电路数量
该软件允许为施工人员创建所有必要的信息换热器盘管元件的设计,如框架和歧管
也可以从UNILAB线圈的计算中导入数据独立地。此外,该软件还通过一个过程进行了增强,该过程允许
在一个或多个之间进行选择的全自动电路的建立解决。完成该软件,有三维设计、绘图和绘图的能力
以最常见的三维图形识别的各种格式输出图形的步骤绘图程序
自动创建回路:根据回路的数目软件直接向您建议一个或多个布局解决方案。它能够
处理管跳过、弯曲和U形螺栓。动/创建电路可手动创建、保存或加载模式。
Isefu/建议的警告指导最终用户创建收集和输出详细信息,这是建立coi所必需的/
换热器(ame和歧管),he/pfu,用于生产部门(成本和coi/in 2D和3D的Vew,可导出图纸(2D in
DWG、ASCII STL中的D、二进制STL、IGES、OB、STEP位图、EMP)独立软件,与UNILAB线圈项目兼容。有可能
打开并加载使用UNILAB线圈创建的项目。(版权原因,本资料只提供使用手册的下载)
